I have a table (rectangle in red), every row in the table has a column (last column) with a formula and is working good. But this formula in the grand total is not correct (yellow mark). This is because Dundas is totaling this last column instead make the formula ($Net line amount$/$Net line amount PoP-1Year$)-1, so the correct amount should be 295.68% instead 159.86% . Is there any way to avoid this total and use my formula in the last column of this table?
Thanks,
