Hi.
I have a Textbox (Filter->More…->String) in a dashboard. Every time the string changes, I want to check it.
I created a script for Value Changed in the properties of this Component.
The first problem is that the Value Changed only triggers when, e.g., I click outside the Textbox, and not when I insert a new character. (Should I use a Timer instead to check for modifications in the input string?).
The second problem is very basic. I want to get the input string, I tried different approaches, but none was, apparently, successful. Could you give me an example? The string should have a specific length and I want to compare it. If it doesn’t meet criteria, I want to change background color.
Thank you.
Best regards,
Tiago Marçal
