At Dundas, we love nothing more than showing off our wonderful customers and all they've accomplished. If that means immortalizing them in our product, so be it!
Dundas BI 5 is right around the corner (more details on that to come) and this is your chance to create Styles and Themes and potentially have them included within Dundas BIs default list of themes!
Here's how you can make this happen:
Import the export file into your Dundas BI instance. When doing the import, make sure you also check the “Resource Data” option under the import “Advanced Options” step so the data for this project is imported as well.
- Once the import is done, change your active project to the “Theme Challenge” project and open the “Sales Dashboard”.
- Now comes the fun part – modify the dashboard styling by creating your own styles to the different visualizations. Once you are done creating styles for the different elements, save all of those styles under a Theme. We recommend trying to apply that Theme to other dashboards in your instance to see what that looks like and adjust accordingly.
- Export your dashboard to an image and also create an export file for your theme.
- Share your image with the rest of the advocates and us (as a reply in this discussion topic)
- Upload both your Theme export file and the dashboard image to Dundas' Sharefile Folder - Make sure both are labeled the same (i.e., Jordan_Zenko_Dundas_BI_Theme)
- Dundas will choose the best Theme and add it to Dundas BI 5 as part of the default set of Themes shipped with the product (this is left to Dundas' discretion – we reserve the right to not add any at the end)
- Dont forget to "Like" the different submissions to show which ones you like the best!
- Each submission will receive 250 points, and the advocate whose submission is added to Dundas BI 5 (at the discretion of Dundas), will receive a bonus 1000 points!
So what are you waiting for! Show us your design skills!
Edit - Submission deadline extended until the end of the Dundas BI 5 Beta
