Hi all,
I am having a problem exporting using both the share and scripting method. for the scripting method here is the script being used
// This implementation uses dundas.export.ExportHelper class and is only available in
// v8 or higher.
// Create the Excel Options
// https://www.dundas.com/support/api-docs/js/#API%20Reference/dundas/export/ExportHelper/Methods/exportExcel.html
var excelOptions =
appendDateToFileName: false,
overrideFileName: false,
openOnCompletion: true,
enableOverlay: false,
selection: dundas.export.ExportSelection.ALL_VISIBLE,
// excludeStyles: isLegacyExportCheckbox.control.value
// Export the Excel with the Excel options.
dundas.export.ExportHelper.exportExcel(excelOptions);
// This implementation was written before the dundas.export.ExportHelper class was
// created. If you are v8 and above you should use this class when exporting as it
// is designed to be simple. If you are v7 and below you can still use this
// implementation below.
// Get the export service.
var exportService = this.getService(‘ExportService’);
// Get the view service.
var viewService = this.getService(‘ViewService’);
// Create the export request.
var exportRequest =
new dundas.export.ExportRequest(
isLegacyExport: isLegacyExportCheckbox.control.value,
// Export Excel
providerId: dundas.constants.STANDARD_EXCEL_EXPORT_PROVIDER_ID,
viewId: this.parentView.id,
viewData: this.getService(“CanvasService”).canvas.viewModel.businessObject.control
// Get the perform export promise.
var exportPromise =
exportService.performExport(exportRequest);
// Setup a loading dialog.
viewService.showLoadingRestCall(exportPromise);
exportPromise.done(
function(exportId)
// Get the Url for the export file.
var exportFileUrl =
exportService.getExportResultUrl(exportId);
// Force the browser to download the file.
window.location.replace(exportFileUrl);
and here is the error given when using both script and share button:
The Scheduler service encountered an error connecting to the Dundas BI server at https://localhost:4000/. The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. Ensure the value for the ‘Internal Application URL’ configuration setting is correct.
