i have been trying out different exports. I have read the documentation and tried the export for PDF and Excel. While the PDF export from the script library works as expected, the Excel export does not seem to work. The exemplary export only exports PDF.
var paperSettings = dundas.print.PaperSettings.fromPaperSize(“A5”);
// Set the PaperSettings orientation property,
// https://www.dundas.com/support/api-docs/js/#API%20Reference/dundas/print/PaperSettings/Properties/orientation.html
paperSettings.orientation = “Landscape”;// Create the PDF Options
// https://www.dundas.com/support/api-docs/js/#API%20Reference/dundas/export/ExportHelper/Methods/exportPDF.html
var pdfOptions =
appendDateToFileName: false,
overrideFileName: false,
openOnCompletion: true,
enableOverlay: false,
paperSettings: paperSettings
};// Export the PDF with the PDF options.
dundas.export.ExportHelper.exportPDF(pdfOptions);
var excelOptions =
selection: dundas.export.ExportSelection.ALL_VISIBLE,
excludeStyles: isLegacyExportCheckbox.control.value
// Export the Excel with the Excel options.
// https://www.dundas.com/support/api-docs/js/#API%20Reference/dundas/export/ExportHelper/Methods/exportExcel.html
dundas.export.ExportHelper.exportExcel(excelOptions);
Thank you in advance
Sebastian Soller
