Export table with stored procedure as a source
Hi all,
I have a table which is generated trough a Stored Procedure which uses 4 parameter values from the dashboard. The table loads (and the procedure triggers) on the click of a button.
The table is loaded and displayed correctly but when I try to export using a script, the table which exports has only the headers, without the values in it. (I only need the export function on a button with script - no trough the built in Share option)
I assume that this is happening because the parameters used to generate the table and trigger the Stored Procedure, aren’t passed from the dashboard to the back-end in the script that I am using.
Tried to add these parameters into the export script as in this example (https://www.dundas.com/support/developer/script-library/export/exporting-with-parameters) , but no result.
Do you have any ideas on how to proceed with this? I am using Dundas 7.0.1.1001.
Thank you!
@octavian.popescu due to the complexity of this issue, if you require assistance from Dundas Support, please send an email to support@dundas.com and we can create a formal support ticket.
