Dundas BI application database
Greetings
i’m not the one who installed our dundas BI
but i need to access Dundas BI application database
to implement this URL : THIS
how can i access it or is there a work through to get each dashboard last access ?
You will need access to the server that the Dundas BI Application is on and Admin privileges.
Here are the steps,
https://www.dundas.com/Support/learning/documentation/install-configure/add-samples-to-an-instance
Unless a Dundas person knows a different way that is it.
