I have timeseries dataset as below with Asset, KPI ,Timestamp and Value.
I want to plot 2 KPI for same asset having different scale value and one KPI is not calculated from other…no any formula relation.
If I select both KPI I get common Y-Axis however scale are different hence unable to do analysis.
Can we fix first KPI Scale on Left axis and second on right axis having Values coming from column ‘Value’ i.e. only one series and X-axis will show timestamp.
Appreciate you response.
Regards,
Prashant
