I'm looking for some advice on how to implement this.
I have an Excel sheet where I want to compare all rows (based on certain key columns) against the values in a SQL database. Purpose of this is just to make sure the data from our Excel is matching up to the database.
I'm guessing I would create the Excel sheet as a metric set and create the data in SQL into a data cube?
Afterwards I'm a little confused as how to do the compare/validation piece. Would I have to merge the two datasets together and setup sorts and states to compare the two?
I also want to highlight any cells that are not equal to each other (Excel vs SQL).
Any help would be appreciated.
Thanks!
