I just wanted to confirm Data Cube Refresh options from the documentation and make sure my understanding was correct. If I do not set a cube to build in memory or build in warehouse and I change the Data Cube Settings to “Disable Data Caching” the data refresh will be done at runtime correct?
The flip side of that question is if I don’t click “Disable Data Caching” the refresh will be done at the point I ask the dataset to refresh through some interaction on the dashboard such as a scripted button or something along those lines?
