Hi, i just figured out that the copy function for Metric Sets doesn´t work like expected. Is there a reason why the states - in my case colours - are not copied?
Thanks!
Thanks!
Hey Marc,
What is your current Dundas BI version in use? Can you try copying the metric set after checking in the original one and see if that helps you?
I use the version 6.0.2.1000, i tried it again - and it worked
Maybe there was a problem while checking in the original file. Thank you!
