I want to change the format of the “Clock In” and “Clock Out” to only show the time, and have the time be in am/pm format. I don’t find anything in the Properties that allows me to set this.
Thanks!
Thanks!
In order to get the desired result, you may create a Custom Time Dimension which only includes the Hour and Minute levels and set the formatting of the selected levels as below:
and then Promote your date/time dimension at cube level.
Or, if you do not have a data cube, you may use the new Time Dimension directly, from the Explore panel -> Data Connector -> your target structure -> select the date/time dimension -> expand and drag and drop the newly created Time dimension to the Data Analysis Panel:
As the last step, open the ‘Visualization’ tab of your metric set and add that dimension under ‘TOOLTIP’ section, as shown below
Where is this tooltip showing? I can’t tell from your image if it’s a row header, a cell value, a column header, etc.
If it’s not a row header, you can edit it like this:
[date:yyyy-MM-dd]
in the settings for the tooltip. This is usually found under the Text portion of the item’s properties.
For more formats, see: https://docs.oracle.com/javase/7/docs/api/java/text/SimpleDateFormat.html
Azar - Thanks!
Ken - I like your solution because I don’t have to alter the data cube, which is beyond my permissions level. I’m having an issue getting the AM/PM to show though…the page of formatting options you linked to says that “h:mm a” should give me what I want:
But instead of seeing 7:25 AM and 11:31 PM, I see this:
I’ve tried other options and some work, some don’t. Does Dundas have a proprietary set of codes?
You may try [ClockIn:t] instead and see the result in Short Time Format.
Here you can find more of these format setting with measure and hierarchy keywords:
(This should work with raw Date/Time dimensions that are not promoted with a custom time dimension)
