Hi, i am wondering where the labeltext can be set for a ParameterCascadingHierarchy? I just get the name from the source table-column. Little example how it looks right now:
Hi @marc.proske,
The ParameterCascadingHierarchy uses the unique name of the column header to derive the names of each selection option in the filter control. You can modify the names by changing them in your hierarchy.
You might also consider using the dependent filter control instead as it has a bit more flexibility.
