Can I combine number of Dashboards and create a report?
I need to create a 4 page report for each separate area. The report will have 4 different charts/graphs (1 on each page). I don't know if this can be done using 'Dubdas BI REPORT'.
I can create 4 Metric Sets and thus 4 Dashboards but, can I combine them in a single file (Dashboard/Report whatever you may call it) in Dundas BI so that once created, I can share it as a PDF?
You can create a report or scorecard without a repeater.
Select an area on the report and use the Add Template Area Before or Add Template Area After buttons on the toolbar to create three additional areas (you may want to delete the Title label first).
With each area selected, enable the property Display Following Content on New Page to have them on different pages, and simply drag your dashboards to the separate areas.
Thanks, @Elia.
