Can I change Data Connector in Data Cube
I have multiple Data Connectors and they all point to same SQL server and database. I also have few data cubes and they all refer to different Data Connectors. Since all Data Connectors is the same thing, I want to only leave one and repoint all my data cubes to it. It this possible? Thanks!
Afternoon Andrei,
You’ll be able to take advantage of the Re-wire feature within Dundas BI to get all of your data cubes pointing to a different/new data source. The following link will take you to the support article, which will include steps on how to get started with re-wiring your data cubes. View the ‘Re-wire the data flow’ article.
Thanks,
Mark
