Hello Patrick,
Quick Update: In summary, there is no way to actually “break the link to a metric set”. When you use a metric set on a dashboard, changes you make in the “Data Analysis Panel - Metric Set” affects the metric set itself. the default visualization for the metric set would remain the same, but would reflect the changes made in Data Analysis Panel. What the update button does is that it updates the default visualization of your metric set to reflect that on the dashboard. (Apologies, I was wrong in my initial response, I should have been more thorough).
That being said. Here are some available options:
- You can build the Metric Set directly on the dashboard (but it’s no longer reusable - it’ll only exist on that dashboard)
- Build out multiple Metric Sets for each dashboard
- Make multiple copies of a ‘base’ Metric Set to fit your needs.
- You could also just build out one Metric Set and simply change the visualization itself to not show certain rows/columns/measures if you don’t want to do the multiple metric sets route. ( You can do this by clicking on “Visualization” in the metric set Data Analysis panel).
Hope this sufficiently answers your initial inquiry.(Honorable mention @mark.barciak for his assistance with this) .
Regards,
Lota.
