How can i fit my portrait dashbaord to landscape ppt? so that i dont have blank space as below:
also, can we modify export size for pdf as well?
Hi Mitsu - if you’re using a resizable dashboard with either scale mode or resize mode it will try to fill based on the export settings that you provide. (Landscape/Portrait/Paper Size)
Keep in mind that you might still have white space based on the height and width of your dashboard as scaling is done with an even height/width ratio. If you want the PDF export to work perfectly, design your dashboard with appropriate proportions such that scaling is possible.
