Does anybody have advice for including a jQuery plugin on a dashboard?
I’ve tried using a combination of the page ready event and script/css in an HTML control, but no luck.
Hi Mark,
Good to hear from you! The ‘correct’ way to add a custom control is to use the API and create your own plug-in.
https://www.dundas.com/support/developer/samples/extensions/create-a-custom-control
https://www.dundas.com/support/developer/samples/extensions/create-a-custom-data-adapter
I am however, much more lazy and typically add these sorts of things using a HTML Label control. Since the HTML Label can directly render HTML, you can add it directly to the text property.
Here is a quick sample of the output created using this method:
Source:
https://codepen.io/AndreiaLopes/pen/ogrKBZ
The HTML code i put in the HTML Label control:
<style> .ui-progressbar { position: relative; color:#362878; width:650px; margin-left:auto; margin-right:auto; } .progress-label { position: absolute; left: 50%; top: 4px; font-weight: bold; text-shadow: 1px 1px 0 #fff; margin-left:-40px; } .ui-widget-header { border: 1px solid #E8D1CF; background: #C3AEE0 url("images/ui-bg_highlight-soft_75_cccccc_1x100.png") 50% 50% repeat-x; font-weight: bold; margin-left:-40px; } </style> <script> $(function() { var progressbar = $( "#progressbar" ), progressLabel = $( ".progress-label" ); progressbar.progressbar({ value: false, change: function() { progressLabel.text( progressbar.progressbar( "value" ) + "%" ); }, complete: function() { progressLabel.text( "Complete!" ); } }); function progress() { var val = progressbar.progressbar( "value" ) || 0; progressbar.progressbar( "value", val + 2 ); if ( val < 99 ) { setTimeout( progress, 80 ); } } setTimeout( progress, 2000 ); }); </script> <div id="progressbar"><div class="progress-label">Loading...</div></div>
Thanks Jeff.
I ended up creating what I wanted in simple javascript/css.
