I'm having trouble getting the correct data displayed based on a user custom attribute. When I log in as Customer1, I'm seeing the same data as Customer2 even though they should retrieve different data.
I have a data cube that I'm using a custom attribute to filter the data. I'm filtering by customer name. I am using this data cube in a few different dashboards.
I have a dashboard that uses the cube. I set each metric to bypass cached data. The dashboard appears to be working correctly.
I add the dashboard to a scorecard. I log in as Customer1. Then I log in as Customer2. For the scorecard it shows the same data. It looks like the same data that I was filtering for as the Developer.
All my other dashboards work correctly. It just seems to happen in a scorecard that uses a dashboard.
Does anybody have any idea what may be going on here? Is it just not possible to do things this way?
Thanks,
Matt
